Chuwi Aupad CN firmware manually flash to Global firmware
Hi, i bought my aupad from Aliexpress, with the serial ZAuPadKK2A250602727 and it comes with Chinese rom without the google services, is there anyway you can provide me the Global firmware which have all the google play services included and a simple tutorial on how to flash firmware to aupad? Thank you so much.
Hi
You can ask the seller how long you have to return it.
When you purchase a product, you can ask what operating system it comes with and if it has the operating system used in your country.
You can contact support and ask if they have the operating system you want.
Got the reply from Chuwi support and managed to convert my Aupad to global firmware,thanks for all the help, problem solved :blush:
My aupad is still stuck softbricked after a update error can the support DM me I need the stock to recover
You must go to the Chuwi website, to the support section, and enter your serial number.
There website does not work.
I’m Sorry but I don’t have Aupad’s link. I’m not a Chuwi’s worker, I only try helping.
You must contact with Chuwi support
yea this shit company never responds forget it i just thru it away im done with chuwi
Come on, take it easy.
We’re users just like you here, and we just want to help.
If you read the posts from the user who created this thread, you’ll see they solved the problem.
In the phone’s recovery menu, there’s a factory reset option; there’s a factory reset option on your device.
On the support page, you can download the operating system and drivers: have you checked?
I think I’ll just share the link here, if Chuwi support doesn’t reach out to you.
Aupad global rom : https://u.pcloud.link/publink/show?code=XZFvvs5ZA8EsL4SpqrXirAExoNVSfQAAx9S7
Tutorial and flash tool : https://www.mediafire.com/file_premium/9jrlbmproproz4t/%25E5%2588%25B7%25E6%259C%25BA%25E5%25B7%25A5%25E5%2585%25B7%252B%25E6%2595%2599%25E7%25A8%258Bflashtool.rar/file
Use it at your own risk :slightly_smiling_face:
Thank you, your words encourage me to continue helping.
from Chuwi support
So they cat fished you with a Hipad file? none of that is for the Aupad… Why anyone wouldnt double check a file is just ridiculously lazy like why even “help” in the first place. Chuwi still hasnt responded for a simple rom file, Why any of you would just let a rich ass company slide on helping there customers is just sad. This is exactly why corporations get away with everything. like I said FUCK CHUWI. YA’LL NEED TO WAKE UP.
I DO TRY TO WAKE PEOPLE UP FROM THERE BRAINWASHED WAYS YOUR WELCOME
So let a million dollar company just slide and not get frustrated when they cant even respond to customers that have spent hard earned money on a product from them? whats next dont expect responsibility? Who is teaching you people this garbage.
Can I use it?
auped ZAuPedKK2A250602660
You have downloaded it and can use it normally?
Now I have the same problem, it's Chinese Rom.
Yes, it’s working perfectly
Hello, same problem here: AuPad from AliExpress, Chinese ROM Android 15, no Google Play. Serial: ZAuPadKK2A250602287. Tried APKs but blocked by system. Thanks for the link, I’ll try it. If there’s an official update, please share!
I had the same problem with two AuPads bought on AliExpress. I installed this ROM without difficulty, and the problem is solved. Thank you.
I have tried, but QFIL show an error “Sahara Fail, Process fail” Do you know the way to fix this error?
