Chuwi Aupad CN firmware manually flash to Global firmware
You’re trying to flash the ROM.
Where did you download the ROM from?
If I’m not mistaken, that message indicates that the ROM you’re installing isn’t for that device.
I have tried both of them. The one is here I the forum an another one that they send to me
AuPad-SDM6858128-ROW-2025-0601_smt-user_SMR.zip (2.3 GB)
And enter in flash mode holding power plus up and down volume.
What sequence to enter on flash mode to install the firmware? Volume up and down plus power at the time with the tablet off?
Doing this Chuwi aupad and the green android quick disappear and the tablet stay black
I don’t have a Chuwi tablet.
The black screen might mean it’s in download mode or flash.
Since you have to connect it to the computer, you must have a command to check if the tablet is connected.
try reinstall the qualcomm usb driver, or use pc with intel processor to flash the Aupad.
Last time i got the same Sahara Fail also when i try to flash the rom using my AMD pc
tablet off, then volume + and - plus power button will get to the flash mode, screen will blink and then stay black
I have tried with three different laptops and all failure. I don´t know what is the problem.
This file was sent to you by Chuwi support
Yes. That is. But no solution
its the mf qualcomm driver problem, somehow it doesn’t compatible with other usb drivers. You just have to try on other pc, or a fresh installed Windows 11 pc
Hi, I installed this firmware but there is no sound on the device, what could be the problem?
This firmware is with google play already installed or should I do anything else after flashing to use google services?
Can you provide more details?
It’s possible you’re missing drivers.
This global firmware is with google play already installed or should I do anything else after flashing to use google services?
all google play services are included in the firmware, no need to do anything.
