I’m having issues with Touchpad on my Chuwi Corebook X. It just stop working, I can’t find any Touchpad options to enable. I’m now having to also connect a wireless mouse.
Any drivers that I need updating or installing that may have gone missing - this used to work and just stopped.
Anyone have ideas to troubleshoot this issue?
Hello Craig, Welcome to the forum.
I have this same issue sometimes. Usually when I restart laptop it works again. I still cound´t find exact root cause but this seems some issue on drivers.
Fn + ESC enable and disable TouchPad but this does not work for me when the issue happens by the time I turn on laptop.
@ChuwiService , do you have any clue if this could be actually driver issue or something else?
@ChuwiService would be nice to know if I can just update drivers. I tried using a free driver update and supposedly all drivers have been updated. I’m hoping for an easy fix before I have to send it back to the supplier, it’s only 4 months old. I’d also expect to see touchpad options within Win 11 why expect some issue with a driver. Can you guide me to Chuwi Corebook required drivers?
Damn bro, I have the same issue on W11 OS system. Idk how to turn on the touchpad(
Hello, I don’t have my battery swollen, the touchpad stopped working. ![]()
when I press Fn+ESC the LED indicator starts blinking slowly. What could this mean? I ran driver update and there is no change. There is no unknown device in the device manager.
What else I could try? Please help
solved - I installed Touch driver GoodixTouchDriver from a post here, restarted and it started working :). The LED is not blinking anymore after pressing fn ESC, the led stays on until another FN ESC. ![]()
