@manonegra222 Do you see any option for that?
If not i will ask tech on Monday.
I seem to remember that there was a 2-in-1 tablet that had a problem with the backlight about 5 years ago and Chuwi solved it with a Bios update but it was due to a technical problem. I don’t know of any patch to make laptop lighting permanent as it would greatly reduce battery life.
Here they solved the problem in the form of a BIOS patch for another laptop model (minibook)
@eNerGy3 the video you sent its deleted i cant see it ;(
Good morning. Updated the link.
Good evening. Have you watched the video?
Tech told me this:
Press Fn+F5 on the keyboard to turn on or off the backlight, and Fn+F6/F7 to increase or decrease the backlight brightness.
As there is no patch for now to make it like always turn on or turn off.
Good morning. It turns out that you can’t remove the keyboard backlight timeout so that it doesn’t turn off after 30 seconds?
Yes we cannot, for that we need a patch, and they are on it. I am collecting all your serial numbers. But i do not know when it will be available.
If a new patch appears with this option, please let me know. Thank you.
I wanted to ask for a new version of the BIOS for another model in order to remove the squeaking of the screen backlight. Thank you!
s/n: JCorBXIW12H23090036
Current BIOS: ADL_P_IDL525_S_S11_V0.59.13 (EC Version 01.08)
Good evening. Can you help with the BIOS?
Your model does not have a new BIOS, giving you another BIOS from another model will wreck the computer. And then there wont be solution.
Hm. Is this bios not suitable?
any Bios that is not the BIOS you have in theory wont be suitable. The computer can crash, as there are many versions with different proccesor. That is why so hard for us to develop patches for every version and proccesors. We cannot provide a solution once for all.
I understood. Can you post the latest BIOS version for this model (s/n: JCorBXIW12H23090036)? Thanks!
I checked and we dont have more BIOS of your model. After yours we changed to a new proccesor. What you have is the latest model i5 1235. We did not product more of them. So i cannot give you the Bios of a different proccesor. I am sorry
Ok. How then can I get rid of the backlight squeaking when working? Do you have a bios patch? Very strong squeaking noise at low brightness.
Good afternoon. Is there a BIOS patch to solve this problem?
I am sorry but as i said previousllyno, there is no patch for this ![]()
