I tried to enable legacy Mode in my laptop but now im in blackscreen, how I can reset my BIOS??? HELP PLEASE :(((((((
Try using an external monitor, probably when you turn on the legacy, the image disappears on the main
display.
I have similar problem.
How do i connect the external-monitor?
Usb-c / HDMI connector?
The type-c connector supports video output, so you can use a type-c monitor or use a USB hub with hdmi out.
Same issue I had and indeed, using external monitor sorted it.
