Chuwi Herobox Pro läßtt sich aus dem Chuwi Herobox Pro bzw Monitor Ruhemodus, somit auch Wondows 10,nicht mehr aktivieren und der Bildschirm bleibt trotz Tastaturaktivirung weiter im Ruhemodus.
My monitor LG is no longer recognized by Windows / Linux MInt after the monitor has gone into sleep mode or by the CHUWI Herobox Pro or by the HDMI connection. The Chuwi no longer recognizes or activates the monitor after the keyboard or mouse has been activated and it then remains permanently black. Even with multiple monitors or other HDMI cables, the problem is always the same. I suspect an error in the BIOS, but I don’t have the BIOS changed !!. Unfortunately, according to the Linux Mint, the CPU runs very slowly because of the wrong driver software, the incorrectly installed graphics card or the wrong driver of the Chuwi, which the Linux reports as an error! Otherwise the PC runs as it should and even with several You Tube Videos in the Multi good.
Hier ist das Problem genau so schon mit der Vorgänger chuwi Box schon so beschrieben:
https://newsabc.net/chuwi-herobox-in-the-test-mini-pc-with-4k-capabilities/
