i need only android, no windows. Which option should i choose in Intel Tool :
Blank/recover/Update ?
i see different system.img file in new firmware now. i am having hopes
If you want to give all space to android you should use this tutorial
it worked my friend!! thanks a lot. You made my day dear. I will now try to change the size to 53GB.
appreciate.
To increase the size of the android partition you must flash using and renaming the appropriate file
Hi, a couple of months ago, after the last windows update, something gone wrong with the usb used for it (not enough space on the pc).
The usb became useless and the update couldnāt proceed, Iāve got this message āinsert the usb to continue the installationā, even if it was connected.
Anyway, Iāve tried to instal it from microsoft using a second usb but nothing, with F7 I could only make a clean installation but Iām afraid to loose my office license (bought just for that pc).
Do you think I could try again with Hi10 Pro Windows(2017.07)?
my HI10 is Hi10 HQ64g421707009.
Thank you
@manonegra222 @Biosham Hello how can I let windows 10 partition, no android. Thanks
Como Ć© que posso deixar so o windows e tirar o android. Obrigado
@manonegra222 would that be possible?
Good morning I need a Windows and Andoid (separated) sw for my Chowi Hi10 Pro sn : Hi10 HQ64G42161206271.
Many thanks in advance
Best Regards.
thanxz a lot Man, Uār my Hero!
Yes, itās easy. You must deleted Android partitions and then extend the Windows partition or reinstaled Windows again.
Here a tutorial in spanish: [ TUTORIAL ] Modificación e instalación de sistemas operativos. [Solo Android] o [Solo Windows]
Hello, This is my tablet: Chuwi Hi 10, model #CW1515, Serial # Q64G42161202200, purchased in Romania in 2017. It works very well, and I am satisfied with it. I have two issues with it: a) after a Windows update, it no longer recognizes the memory card b) it no longer updates Android; it is stuck on version 5.1 Can you help me resolve these two issues? Thank you.
The issue of the SD card not being recognized is a known and recurring one. It can be temporarily resolved by entering the BIOS (pressing Esc immediately after turning on the tablet) and exiting without changing any settings. As for the Android update, it is impossible because Intelāthe processor manufacturerāstopped releasing Android drivers for later versions of the OS, a decision that effectively put an end to dual-boot tablets.
