Chuwi Larkbox X n100 - cooling fan specs?
Has anyone successfully modded the Chuwi Larkbox X n100 cooling system? As in replaced the CPU blower type fan to axial fan or maybe even replaced the radiator? Can you share your findings or maybe someone from Chuwi can enlighten me?
I believe that fan is a 4-wire one but what’s the voltage (12v or something else)? Does it follow any standard and can be replaced by just any other same voltage same number of wires fan or is there anything special about it? What is the type (dimensions) of the fan connector and pinout? What are the dimensions/placement of mounting holes for the radiator? I am aware that probably any mod will not fit the chassis but that’s not a huge issue for me.
That is too much for us :slight_smile: but maybe other users did it. Did you check Reddit? usually there are some users there too
