Chuwi ubook PRO 8100Y
Hi. My ubook pro goes every time in to BIOS instead of just booting windows when i power it on. The only way that i have to reach windows is by selecting windows manager on boot override in BIOS. Can someone help me in this matter?
It is strange but we will try to correct it
You should go to the Bios, boot tab and go to the boot preference command line 1. Check if Windows appears there. If not, hit enter on that line and select Windows in the popup. Once this is done save changes and exit.
This is my current settings in Bios. Seems all good for me except the blue arrow on Windows Recovery in Boot Override.
I was thinking to restore the default image but i prefer to do it as last resort. Everrything is working fine except this annoying thing.
Does the UBook go into BIOS if the keyboard is not attached?
Have you tried changing the BOOT MENU setting to DISABLE?
Have you tried to Restore Defaults in BIOS?
I am not sure why you have a Boot Option #2. Do you have a dual boot system?
Yes.
Yes
Yes
I dont know either and the tablet is a single boot system, I didnt change anything. I only noticed this problem when i needed to restart the tablet after installing some programms. When i turn it on for the 1st he went straight to the BIOS but i thought it was normal since it was the 1st boot.
The UEFI Bootloader might be corrupted. I would suggest searching the Internet on how to repair the UEFI Bootloader for Windows 10. There are a number of steps involved. I have done this for several computer systems and it sometimes will resolve these types of issues.
If this doesn’t help then you can try to repair the Windows 10 system files as below:
Run the following commands in an Admin Command Prompt (or Admin Powershell):
DISM.exe /Online /Cleanup-image /Restorehealth
sfc /scannow
So i solved the problem by flashing a older bios that i founded in this forum, but now i have another problem. When i upgraded de firmware for de H6, half of my touchscreen doent work when i touch but its all fine using the pen.I already did what the rest of threasts says to do included installing the windows 10 provided. The odd thing is when i used guitartest and did the test thing, all the touchscreen was working but the axis were inverted.
I figured out how to solve this problem. So i followed the powerpoint of the 8100Y TP drivers that you guys dropped in other threaths but i did a extra step and now my touchscreen is working good. So follow the power point until you reach 4th step and stop there. because you need to update the firmware before doing the upload of the cfg file. To do that open guitartestplataform->Tool->TP IC FIRMWARE UPDATE->Open de bin file (each is in same older of the guitartestplatorm if you extracted the 8100Y TP correctly)-> Hit update. After completing the update, you just need to follow the rest of the powerpoint (upload de cfg file and send. exit the test mode).
