I just got my N100 minibook x a couple of days ago. I bought it from Amazon.
Serial:
ZZMinBXHY4H240701531
I’m seeing constant 100% CPU utilization in Windows Task Manager. The systems seems to be working ok (some hang ups but maybe that’s just Windows 11? First time with it.) so just wondering if this is expected within this sytstem.
The CPU is at 100% on a fresh install on a fresh boot, no programs running, just Windows. If this is not ok then i should look into returning but i’d like to confirm that this is not intended behaviour since i have to cover the returning costs.
I don’t have the minibook right now but usually it’s just the Windows System Idle Process at the top, maybe with Edge browser opened it jumps to the top but when no apps are running the System Idle Process is the top process consuming CPU.
By a fresh install i mean the device just as it came from the box. I always saw 100% CPU usage. I installed updates to see if any driver update could fix the issue but no luck.
It showed 100% CPU utilization out of the box, with no apps installed. Could i try reinstalling Windows? Can you provide a Windows image and drivers for trying a fresh installation?
Is this a Windows update? That can take quite some CPU load. In addition looking at the frequency it seems you did not enable Perfomance in your power settings.
Windows update can take quite some time to finish. Especially when the system is not in performance mode.
