Corebox 4th fan replace.
If I disconnect the fan and install an external solution for cooling separated from corebox, will my corebox 4th work normally?
Will it boot normally?
Is there any tutorial on how to replace the fan, a detalied tutorial?
Can’t confirm, but it should work fine without the fan attached.
And the external fan should be fine depending on its static pressure, speed, and most important position compared to intake and outake of air.
I hope you are right, thank you.
Open for other suggestions.
Have you checked the reddit forums? Users are always doing DYI there with our products.It should work but we cannot guarantee…
Yes I have, but there is no step by step tutorial.
