Corebox i5-5257U Bios Lock - Need directions on bios reset
CoreBox 256G20092647
Used Facebook Marketplace Dec 5, 2024
I purchased a used CoreBox CWi526 without an SSD and the seller told me that it has a password lock. I thought it was a Windows password and I would reload the OS altogether. I find out that is a bios password and I would like the reset bios altogether and start fresh. Can someone explain the procedure to reset bios to factory? I have tried unplugging the bios battery, pressing and holding in the power button but no luck. The unit does not have a bios reset button.
Your help is appreciated.
I got my answer from Chuwi support:
Dear customer,
Regarding the solution to the issue of forgetting your BIOS password;
1.Replace the motherboard .
2.Send the device to professional repair personnel, who can reflash the BIOS using a programmer.
We cannot clear the bios password remotely.
Regards,
Chuwi Official Support
CHUWI Official Support Team from CHUWI INNOVATION LIMITED.
Just in case you need the BIOS
Thank you.
Some good news. I was able to unlock the bios. First off I was making a mistake in regards to the bios battery connection. I thought it was on the top of the motherboard along with the fan plug. I was wrong. The other plug was the on/off switch. I took out the CPU cooler because it blocks the 4th screw that you need to remove. When I was able to pry the motherboard out of the housing I found the actual bios battery and its connection on the bottom of the motherboard. I also found 2 “reset” buttons. Actually I have no idea what they are for, but I unplugged the bios battery and pressed both “reset” buttons for about 10 seconds. I reconnected the bios battery I started the Corebox back up before putting it in the case and without the CPU cooler. I had it on long enough to see that I could actually get into the bios now and turned it off. I put everything back where it belongs and was able to again boot into the bios. I have no drive at the moment so it will only go into bios. I have an M.2 Nvme drive on order and it should be here by Friday. I will look at flashing the bios with the latest version that Chewi provided in this thread and go from there. Took some pictures to go along with the tale.
ChuwiSpainSuppport,
I have the CoreBox up and running, but I am trying to install a M.2 drive in the computer and it is not being recognized. I picked up a TEAMGROUP MP33 256GB SLC Cache 3D NAND TLC NVMe 1.3 PCIe Gen3x4 M.2 2280 Internal SSD TM8FP6256G0C101. Did I pick up the wrong kind of M.2? Amazon.com: TEAMGROUP MP33 256GB SLC Cache 3D NAND TLC NVMe 1.3 PCIe Gen3x4 M.2 2280 Internal SSD R/W Speed up to 1600/1000 MB/s Laptop&PC Desktop TM8FP6256G0C101 : Electronics
Any idea on the thread size for the M.2 hold down?
I am able to boot the computer from a 2.5" SSD, but would prefer to use the M.2 and use the SSD for storage.
Thanks in advance for any assistance.
Joe
Well, I figured out the question of what type of M.2 SSD I need. It needs a M and B slot and SATA only.
I still need to know the thread count and pitch for the hold down screw.
The thread size is 1.4x2. It is definitely an off size, but that seems to be Chewi.
I am slorry sometimes this forum does not put the threads on the top so i am not able to see them
how can i help? because im not sure what is question :slight_smile:
I figured out all the issues I was having on my own and posted those answers in this thread.
