Hello I own a Chuwi Hi12 and I am planning to upgrade buying the Hi10Max, as my Hi12 is showing some problem with the touch screen.
The Hi12 had a vey nice cover case.
Does the Hi10Max have a cover case?
If so, is it similar to the one supplied with the Hi12 6-8 years ago?
How can I buy it or is it included in the package?
If not, do you know any cover case compatible that provides a good protection against accidental bumps and drops?
Thank you in advance.
