CWI531-N4120-Bios problem
Hi everyone. I have a problem with my Chuwi Tablet. After press power button, tablet didn’t start, just show orange indicator approx 5 sec and went out. Then orange led shows again and tablet start in bios recovery.
Anybody have factiory Bios on this model??? Help me please. T_T
I have this model:
Chuwi Hi10 X
Intel N4120 8GB RAM
Intel UHD Graphics 600
Model: ZHi 10XEW1H230400085
Type: CWI531
Hi
What were you doing to make it only enter the BIOS ?
I don’t think it’s a BIOS problem.
Hi!
Before that i change some parameters in bios, but i don’t remember which ones. Т_Т
After that tablet dont start up. Only black screen.
You can check in boot that it is selected to start the system.
another option in the last tab exit, to restore the default BIOS.
I’m already chose this option “restore the default bios”. It doesn’t work. :sob:
If you change the BIOS settings, you need to know what you’ve changed: write down which parameters you’ve changed so you can revert.
In the recovery, it shows that you don’t have a ROM loaded, which is like saying you don’t have an operating system.
Can you upload a photo of the other BIOS tabs?
Make sure the letters are clearly visible.
If i right remember i change the parameter “TOLUD” and something else…I change only 2 parameters. I’m already reinstall Windows. But tablet still show me “recovery” every start up.
Do you only have Windows as your operating system?
Maybe you changed:
In save, exit, boot override, I don’t see the configuration options.
In boot, you may have changed something.
In advanced or chipset, you may have changed something.
I don’t see the parameter: tolud
It’s complicated. Do you have a friend who knows about computers?
This confirms that you have blocked the boot.
Thanks for you support :+1: so much!
On my stock bios i changed 2 parameters(i dont remember whisch ones) after that, they didn’t start up. I reflash my bios chip with programmator to bios from other tablet model. Now tablet start up but with ROM error. With my factory bios tablet dont start. It totaly broken.
That’s exactly why i need a factory Bios =)
Its amazing !!! I flashed it and tablet WORKS!
ChuwiSpainSupport- BEST SUPPORT EVER! :star_struck:
