Diplay Port 1.4 AuBox AMD Ryzen 9
Diplay Port 1.4 AuBox AMD Ryzen 9 IT DOES NOT WORK.
I’ve tried many cables without success. Can anyone help me? Thanks.
Because it’s not working:
You’re connecting one screen or two screens
I plug a monitor into the HDMI port and another into the DP 1.4 port, but it doesn’t work.
I was told that it depends on whether the DP port is active or passive. How do I know?
Generally, you should first check that it works by connecting a single monitor, the HDMI cable, and the DPI cable.
Then connect both monitors.
In Windows, You have to configure the extended desktop.
If the extended Windows configuration isn’t working, You might need to configure it in the BIOS.
It’s always a good idea to look for a tutorial on YouTube.
I’ve tried a lot, and it doesn’t work. Even the technician at the store who sold me the PC and monitor managed to fix it; in the end, he connected it via USB-C.
There’s no option in the BIOS for the DP port.
109
Someone told me I need an Active DP adapter. I have no idea. I haven’t found anything on YouTube that works.
You’re telling me you connected the computer’s DPI to the HDMI monitor and there’s no image.
The monitor doesn’t have a DPI
How to connect a DPI card to an HDMI monitor
Yes, Monitor only HDMY
