After a Windows upgrade on the laptop, the RAM dropped to 3GB, the sound stopped working and I get these Chinese letters (5.2/5.3GHz帯無線LANの屋外利用は法律で禁止され) every time I turn on the laptop. I have read in forums that it is something with the BIOS, can you send me the original BIOS or the new one that is working fine to flash it and instructions on how to do it?
Instalează Intel assistence de pe site intel .Când pornești laptopul apasă pe tasta del.Vei intra in bios .La ultimă partiție vei găsi set default valuri.Seteaza aceasta valoare.Apoi setează save și ieși din bios Reporneste și va fi bine.
I tried this but it didn’t work, I’m pretty sure it’s a problem with the BIOS, I need the correct BIOS for this model and a way to flash it, was anyone able to fix it?
Se poate sa fie defect fizic.Reparare biosului îl găsești pe YouTube.Orsicum ajungi la service.Incearca la chuwi global service numai ei au biosul original.Sunt service dacă erai in Romania ți-l reparam mai ales mai am o tableta la fel la vânzare.
