After upgrading Windows on the laptop, the RAM was reduced to 3GB, the sound stopped working and I get these letters in Chinese (5.2/5.3GHz帯無線LANの屋外利用は法律で禁止され) every time I turn on the laptop. I read that it is something with the firmware, can you send me the solution?
Try installing this file:
Hi10 XRdriver text**
@manonegra222 do you have an idea why would that happen?
I made a mistake here, I posted this topic in the wrong category, the correct category is Hi10X, not Hi10XR, sorry for the confusion
You must explain if was a Windows update or if you did an update or reinstalation
