Freebook N150 no touchscreen
Freebook N150 touchscreen not present. Just received it today and started updating windows.
Device name Chuwi-Freebook
Processor Intel(R) N150 800 MHz
Installed RAM 16.0 GB (15.7 GB usable)
Device ID C56928A2-9C33-4EAD-824F-C4C10F417312
Product ID 00356-07538-59892-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Edition Windows 11 Home
Version 24H2
Installed on ‎7/‎8/‎2025
OS build 26100.2605
Experience Windows Feature Experience Pack 1000.26100.36.0
The info says clearly “no touch or pen input available”
In device manager there is HID device not starting:
Hardware IDs:
ACPI\GXTP7386\4&1BAC3B73&0
ACPI\VEN_GXTP&DEV_7386
ACPI\GXTP7386
*GXTP7386
Model/serial is JFreeBCY1I250501105. Bought from chuwi.eu.
You’ve reinstalled Windows.
Go to the Chuwi website, support, downloads.
I said clearly I did not install anything. Windows started updates. That date 7/8/2025 is weird. Today is 7/7/2025.
Ok, after a day of windows updates and restarts (and the feeling of regretting buying a Chuwi device), I came to the final conclusion and entered the recovery and reinstalled win11 “from the device”. I don’t really understand yet from where it took the installation files, I had the OS zip downloaded from Chuwi support in download folder, but the reinstall just went through without asking me the source. Does it have an install partition? I’m an engineer but I don’t install Windows or Linux everyday to know all the details. Anyways, I kept the personal files and in 20 minutes the windows was up and running fine, touchscreen working.
It’s the win11 update that screwed the touchscreen driver. I didn’t even have the time to check the touchscreen and stylus after first boot and setup, because the update had already required a restart and from that point on the touchscreen driver was damaged.
I checked the device hardware ID (that was not starting after update) and indeed it is the touchscreen HID device. So, what do I do now when windows asks for updates?
So for future reference, since this will most likely happen for other people, if touchscreen stops working, it’s the windows update. The device worked fine, just no touchscreen.
One thing for Chuwi engineers: the support site links for OS and drivers point only to OS package, 12GB. There is no drivers only package. Please fix that and add the drivers package. Also, check why the windows update creates this mess. Thanks!
Its the Windows update who sometimes remove drivers, and this happens.
Right now, we dont have a clear solution for that. They are working on it.
The drivers package can be found in this topic: FreeBook360 N150 can't download drivers - #4 by ChuwiESnotactive
Window has updated to latest build and I don’t have touchscreen working. Again. The HID device cannot start.
Guys, check your shit with Microsoft, Chuwi devices are garbage. Any update from microsoft disables functionality? How is it that you can say “we don’t have a solution”?
