I found a m.2 slot on my Gbox Pro. Does it work? or has it been disabled?
I’d like to use it to connect an egpu
Thank you! So it’s a Sata m.2 slot? NVME’s won’t work?
I’m not sure about about nvme
This processor support PCIe, so nvme should work?
Thanks for your help. m.2 slots can be a a little confusing. Some can take sata or nvme, some can only take one or the other
Hi, on my chuwi gbox 4g the M2 Pcie does not work.
