My Gemibook XPro N100 power off randomly after a few minutes of use, even it´s full charged. Never does it if connected to power supply.
Was bought in 2023 agust in Aliexpress
S/N JGeBXPCY1H230301248
Thanks for your support.
Во время использования или вы на пару минут отлучаетесь?
Did you also check, the sleeping mode, and the configuration in save battery options?
Hi, checked energy options and that isn’t the problem. Reinstalaed OS and problem not solved.
Thanks for your response, it’s not a power configuration issue
Thank you for your contribution, all of that is more than reviewed
Thank you for your support, all of that is more than reviewed. I bought you 4 chuwis laptops and only this one has the problem
Биосс попробуйте сбросить
Then you have two options:
Because i dont know where you are from, IF tis Europe send it to repair to Germany (you pay the shipping ) if its other area , you need to send to HK.
I suggest you to go to a local store to maybe ask whats happening if its software it could be easily solved maybe. But if its hardware, then need to send it.
Hi, thank you for you answer.
Finallly I solved the problem by opening the back cover and disconnecting the battery for a few minutes. This seems to have reset something and the battery is now functioning normally. I’m writing this here in case it can help someone in the future.
Come si fa?
Finalmente está solución no funcionó, así que busque otra que si funciona: hay que entrar en la bios y modificar algún ajuste relativo al ahorro de energía. Ahora mismo no recuerdo cuál
