hello. my gemibook is always automatically shutdown even the charger is connected or plug in… is there any solution to solve this problem…
Check the battery saving settings of windows…
i already did that… what are the settings for battery savings? can you give some…
Noong Huw, Ene 21, 2021 nang 4:46 AM, sinulat ni Angelos via CHUWI | Official Forum <chuwi@discoursemail.com> ang:
can u give your settings so that i can repair my gemibook pro… because mine is automatically shuts down., a little help is very much appreciated…
Set everything to none in battery standby to test it.
hello. i got the solution… go to BIOS settings … press DEL Key before the CHUWI Logo … then advance menu … then system component menu… then find the Embedded Power Intrumentation…set it to disable…
that’s it…
