What specifically did you do in your BIOS settings? I just got a SanDisk SN5000 4TB PCIe 4x4, and I cloned it successfully, with a Vantec Nexstar SX SATA/NVMe to USB-c adapter. Chuwi said my Gemibook Pro is SATA 3 and Gen3x2 compatible. All I need is the settings.
Hi, Ricci. At BIOS go through points chipset → south bridge → pci → port 5 and change state to ‘enable’, then change ASPM to ‘disable’. I don’t know why active power management (ASPM) prevent PCIe SSD from initialyzing, but it is. I don’t remember exactly, but perhaps chipset point is in the advanced settings.
