Glass Screen Protector
Hello Forum Members,
I ordered a glass screen protector for Chuwi Hi10X on Amazon.
I know that Chuwi Hi10X has its own laminated screen protector.
Do I need to remove this laminated screen protector first and then apply the glass screen protector?
If so, is it easy to remove the laminated screen protector?
Thank you.
I just want to update.
I purchased a glass screen protector.
I removed the original (Chuwi installed flexible screen protector) and applied this glass screen protector.
It is working great and the size is perfect.
Hi, I have a Chuwi UBook X and the factory screen protector is damaged. What tools did you use to remove it? It seems to be really well attached.
