HeroBook lost network settings and now no wifi
Hello,thank you for the quick reply!
just 1 more question : the image you uploaded could be useful also for me ? i checked in the file unattend.xml in the folder IMAGES and i read some info that will be written in the registry,and actually in my pc is different,i.g. HKLM\SYSTEM\OEM" /v “OEMID” /t REG_SZ /d 1900234-CHIWEI-NQ14E-20191101 /f ( mine is more recent). could it be a problem? and ,if no, i could use also another usb bootable with another win10 image made by me in another situation and that i already have prepared?
thank you again for your help:-)
Nicola if you own chuwi herobook you must use the image i have uploaded its the chuwi herobook official windows 10 image. If you use another one that you have created it wont work. I tried it so believe me the only way is to do what i say.
Hi bizzy,
The files that you have uploaded can they be flashed onto an SSD in the herobook? Or does it have to be the Emmc? Thanks
These files are made to flash the internal emmc of the laptop. In case you want to use and run windows through an ssd you have to clone the emmc storage drive into the ssd and after that change the boot order through bios. You can use a free program called minitool partition wizard to clone your emmc storage drive to the ssd drive
hi brother im facing the same problem but the only diference is that I have herobook PRO
can I follow your steps or do something else?
Φίλε μου τα λινκ που έχω βάλει εδώ σε αυτό το topic δεν κάνουν για το herobook pro αλλά μόνο για το απλό herobook. Για το herobook pro χρειαζεται να κατεβάσεις από δω όλα τα αρχεία και μετά να τα αποσυμπιεσεις να γίνουν ένα αρχείο. Στα αρχεία που είναι να κατεβάσεις από το mediafire παρακάτω θα βρεις έναν φάκελο EC όπου όταν τον ανοίξεις θα βρεις ένα αρχείο EC tutorial αυτό το αρχείο έχει μέσα τις οδηγίες για να κάνεις ένα φλασάκι bootable το οποίο θα χρησιμοποιήσεις για να κάνεις εγκατάσταση τα windows 10.
Αν χρειάζεσαι άλλη βοήθεια στείλε μου να σε βοηθήσω περισσότερο
Thanks for answering you really save my ass! I will start the reboot now and I will let you know if there is any problem.
σου εχω στειλει προσωπικο μηνυμα
Here is the issue:
After applying Windows 10 updates, at some point the Network Stack in the UFEI BIOS had all sub items disabled. Having them disabled prevents the device from showing up in the Device Manager.
To fix:
  1. Windows Flag Icon (left click)
  2. (Left click) Settings (The gear Icon)
  3. (Left click) the Update & Security
  4. In the left hand (grayed column), left click Recovery
  5. Locate Advanced startup
    Under this (left click) Restart Now
  6. Left click Troubleshoot
  7. Left click UFEI BIOS Settings
  8. Look through all the BIOS settings until you find “Network Stack”
  9. Enable all items under Network Stack.
  10. Save with Exit (BIOS Settings)
  11. Your Wireless should now be available (after reboot is finished)
non funziona lo stesso
You can also activate the UFEI BIOS during power-up by pressing the escape key repeatably.
happening to me now… what is the best solution!?? tried the "8-wifi-sthwfw4169_20.100.0.4_g driver but it still did not work after restart… any accurate tips??
same problem here. No WiFi and audio.
What best way to solve this?
Same problem for me, no network card detected… Sometimes when i restart the computer it work again… It’s the same when i try with linux. I think the network card is poor quality…
