Hi
I just bought a new HeroBook. I completed the Windows 10 installation. Now the WiFi does work anymore. I tried to reinstall Windows 10 (Update&Security - Recovery - Reset PC) but nothing changed. After some reboots the Wifi is able to connect for few seconds that it loses the connection again.
Please advise
Me too we need help chuwi i tried through driver booster to update drivers and i lost entire wifi connection
Hello
me the same problem. a solution is urgently needed so we cannot use the herobook. please respond urgently. Herobook pro 14.1 8gb/256gb. Is there a new BIOS firmware to install? I am waiting for a quick urgent response, I have to work with this Herobook pro rgds
Try to roll back wifi driver in device manager
Or try to reinstall drivers https://www.mediafire.com/folder/4fyvzpdqd86mu/Driver
Or try to reinstall system https://www.mediafire.com/folder/cy9zu7pylodya/windows#pepomq7svedja
Tutorial for system installation http://www.mediafire.com/file/pvfwfpjr1pqpuyx/Herobook_Flashing_Tutorial.docx/file
Files for herobook PRO [Herobook Pro] [Official Version] Chuwi Herobook Pro Drivers,Windows
rollback bluetotooth driver saved me from driver booster update of wifi drivers, thanks a lot!!
