I just ordered and received this Chuwi 2024 Hi10 Max 2 in 1 Tablet: https://www.amazon.com/dp/B0CLRKBWQ6?ref=ppx_yo2ov_dt_b_fed_asin_title Serial ZHiMaxHZ1H241004229 Now if you look at the picture of this on Amazon: The keyboard connector is on the side that faces down when the kickstand is used, however the device I received the keyboard connector is up and on the opposite side of the tablet and the power buttons etc is on the down side; same side as the kickstand and you cannot flip the magnetically attached kickstand to the other side so that the buttons are up and the keyboard connector is down on the unit I received. This makes it unusable to me as you can’t use the kickstand and keyboard at the same time so why is this?
The Kickstand is not correct . Check this video
