Hi10 Max + Power Bank
I recently purchased the Hi10Max and am planning to purchase a power bank charger.
I’ve seen others in the past have had compatibility issues, as the Hi10Max charges via USB-C power delivery.
What should I buy to avoid issues? Any special cables or adapters?
On the other hand, the Hi10Max receives 12V 2A, if I’m not mistaken. What specifications should the power bank charger have? Should it be at least 12V 2A or at most 12V 2A?
I’m in Argentina. Best regards.
Tablet power supply requirements (when using a third-party power supply):
- mandatory requirement - support for the Power Delivery protocol;
- recommended requirement is at least 35 watts.
What’s the problem ?
You’ve lost the charger ?
The charger has the voltage and amperage specifications for your device.
Have you ever thought that a person just doesn’t want to have and carry several chargers (from a phone, tablet, etc.), but use only one of them for all devices?
You are a forum administrator or moderator
Does it affect anything?
I am also interested in finding a powerbank that can charge this device (as it is 12V 3A 36W per power adapter specification). Anker’s offerings seem interesting, but I wonder if there are others better / cheaper.
Above, I have already given the requirements for the tablet’s power supply, which relate to both the charger and the powerbank:
  • mandatory requirement - support for the Power Delivery (PD) protocol;
  • the recommended power of the device should be at least 35 watts.
Look for a powerbank that meets these requirements.
