Hi10Max power adapter
Any alternatives for the supplied power adapter?
I tried a 12V 3A power adapter that works with the Pine Tab 2 yet it does not work with the Hi10Max.
We do not recommend using another charger than the one that comes with it. If the charger that comes with the tablet it came defective, Contact us and we will replace
Hello, just got HI10 Max and I see that i can’t charge it with my phone chargers or powerbanks. is there maybe i can do in options\bios to enable it or i am stuck with bringing original charger with me all the time?
Did you read the post above ?
they do not recommend,but can i use it anyway.
I’m not going to be to blame if it goes wrong.
No, the charger of Hi10Max is 12V , phones is 5V. You will fry anything else..
