Hi, can anyone post link to download all Windows 10 Drivers for fresh install ?
Many Thanks but the link for the drivers does not work ?
can you put your serial number?
Hi, sorry for the delay its LQ64G42170208681
Hello all. I have a request for manonegra222 about hi 10 plus LQ64G421711*****.
After a new and fresh windows 10 install, the drivers downloaded from this forum help me to recognize all devices but 2, I think related to the 2 cameras. Seems that only these devices doesn’t function. Could you help me to retrive the correct drivers for windows 10 to have cameras work properly again? thank’s in advance and regards.
HELLo please help i have this tablet SERIAL H10 LQ64G42170202938 CHUWI Hi10 Plus CWI527 with fresh windows 10 but i cant find wlan drivers… please help
hello please I have a tablet HI10 plus LQ64G42180304615 but the touch screen cannot be used… please help me
Have you touched something in the system? Have you reinstalled Windows?
You have to explain a little more to be able to help you
Hi, my Hi 10 plus does see wifi networks but it can not connect. What can I do?
Hello Sir,
I need
any help will be appreciated.
If your tablet is dualboot, the bios only Windows will not work, you must follow this tutorial: [TUTORIAL] How to remove Android and install Windows on a dualboot tablet (Intel Processors)
After solve a bluetooth problem to conect headphones it works connecting to hear nice, but now its microphone does not works, neider microphone on the tablet, neider speakers on the tablet, happened that windows do not install properly sound drivers of my Chuwi tablet, because during the repair process I uninstalled software that I souldn’t, the original sound drivers that windows protect to install because are unsigned, and probably something else. So I think best to do is a fresh windows install:
Can anyone post link to download all Windows 10 Drivers for fresh install?
Hi10 Plus , serial number: LQ64G42171102941
Thanks.
hi, please help me for Hi LQ64G42170208691
i don’t know how to reinstall android & Windows
thank you
If you yourself don’t know how to reinstall the operating system, I recommend contacting specialists. Is there a technical service center in your city?
Hi.
I installed windows 10 but my camera does not work. I tried to flash different BIOS.
Give the correct BIOS and camera driver for my device. Thanks!
Hi10 Plus LQ64G42170206022
