Hi there,
unfortunately the forum is reset and i can not see the old entries.
With intel drivers the tablet is often “restarts” the screen: it goes black and then it is there again.
The Solution / Fix for that was to set an registry entry.
In the old Forum an moderator postet that solution. Now I can not find the old Forum posts anymore.
Does somebody know the “trick” what i have to do in the registry for that?
Thanks in advance
Write Device Manager.
