Hey. I need help. I’m on a Hi12 tablet Q64G45160901890 performed the recovery of the Windows 10 system. After that I got the start screen with “Another user” I do not know what it is. I can not enter a password and enter the system. Help!
Chuwi delivers its products without created users, so I think you bought the tablet in a store like Gearbest or Banggood that usually try them, creating a user.
As you do not know the password and, although there are some tutorials on the internet and youtube to find out, I advise you to do a new installation of Windows 10 home with a flash drive with the media creation tool downloaded from the Microsoft website. You just have to put “get Windows 10” in the browser.
Once you have it, you must turn on the tablet with the pendrive and a keyboard / mouse on and pressing F7 intermittently until the boot selection menu comes out and there you choose the pendrive. The windows installation program will start and choose the custom installation. When the window arrives asking you where you want to install Windows you have to select and delete, one by one, partitions 12, 13, 14 and 15 and indicate as the installation destination the resulting unallocated space without creating any partition or formatting nothing. When I ask you for the Windows key, select I don’t have a password since it will activate on its own.
When the installation is finished, it is time to install the drivers. It is logical that, after a clean installation of Windows, the system does not recognize the drivers of non-Intel devices. This happens on any device of any brand.We must then install the drivers that Windows has not been able to install.To do this, after downloading the drivers of our tablet or laptop model and unzipping them into a device storage folder, disable Windows protection for the installation of unsigned drivers.To deactivate this protection, press start, restart with the shitf key pressed, and restart now. When you restart, an advanced reset screen will open in which you must press 7 or F7 to deactivate the protection and it will restart normally.
It is time to go to the device manager, by clicking on the start button with the right mouse button and in the menu choose device manager, and see in the device tree the drivers that are not correctly installed. (they have a yellow triangle).You have to click on each of them with the right button, driver properties, update driver. On the next screen, choose the option below “search for driver software on the computer”. On the next screen “choose from a list of available drivers on the computer” and on the next one you must click on the use disk button; The browser will open and select the folder where you have unzipped the downloaded drivers, checking the option to search in subfolders.The system will install the device driver. You have to repeat this process with each of the devices with a yellow triangle. Keep in mind that if you restart, the protection will be activated again, so you must activate it again when you have to install a driver.
I want to just enter the system. Delete user. I do not need a complete reinstall. Maybe someone else had this problem?
As I told you above, there are many tutorials on YouTube to recover the password. If you don’t want to follow any, you only have to reinstall Windows.
an example in spanish: https://www.youtube.com/watch?v=Wf99C0kY4ZE
Hi, thanks for the details of re-installing Windows 10 with pendrive. Does any steps of whole process require to enter Windows Product Key?
Привет. Я не переустанавливал систему. Я просто вернул все настройки к заводским. Не могу ввести пароль пользователя. Что делать?
Есть много способов сбросить пароль, но лично я всегда пользуюсь этим способом:
Спойлер
- Загрузитесь с загрузочной флешки Windows 10, затем в программе установки нажмите клавиши Shift+F10 (Shift + Fn + F10 на некоторых ноутбуках). Откроется командная строка.
- В командной строке введите regedit и нажмите Enter.
- Откроется редактор реестра. В нем в левой панели выделите HKEY_LOCAL_MACHINE , а затем в меню выберите «Файл» — «Загрузить куст».
- Укажите путь к файлу C:\Windows\System32\config\SYSTEM (в некоторых случаях буква системного диска может отличаться от привычной C, но нужную букву легко определить по содержимому диска).
- Задайте имя (любое) для загруженного куста.
- Откройте загруженный раздел реестра (будет находиться под заданным именем в HKEY_LOCAL_MACHINE ), а в нем — подраздел Setup .
- В правой части редактора реестра дважды кликните по параметру CmdLine и задайте значение cmd.exe
- Аналогичным образом поменяйте значение параметра SetupType на 2 .
- В левой части редактора реестра выделите раздел, имя которого вы задавали на 5-м шаге, затем выберите «Файл» — «Выгрузить куст», подтвердите выгрузку.
- Закройте редактор реестра, командную строку, программу установки и перезагрузите компьютер с жесткого диска.
- При загрузке системы автоматически откроется командная строка. В ней введите команду net user чтобы посмотреть список пользователей.
- Введите команду net user имя_пользователя новый_пароль чтобы задать новый пароль для нужного пользователя. Если имя пользователя содержит пробелы, возьмите его в кавычки. Если нужно удалить пароль, вместо нового пароля введите двое кавычек подряд (без пробела между ними). Настоятельно не рекомендую набирать пароль на кириллице.
- В командной строке введите regedit и перейдите к разделу реестра HKEY_LOCAL_MACHINE\System\Setup
- Удалите значение из параметра CmdLine и установите значение SetupType равным 0
- Закройте редактор реестра и командную строку.
В результате вы попадете на экран входа в систему, а для пользователя пароль будет изменен на нужный вам или удален.
