Following the indications here I’ve successfully reformatted my Hi13 and installed Windows 10 1909 on it. Got through the inverted touchscreen issue but am still stuck on the bosch accelerometer driver issue and haven’t found a clear explanation of what to do to overcome it.
I’ve understood that the driver that Windows 10 goes and grabs is too recent and doesn’t work on this tablet. But the drivers in the various driver packages I’ve downloaded both from here and TechTablets don’t appear to have a compatible driver for this sensor.
Any clues would be appreciated.
Thank you,
Brad
I have exactly the same problem, did you find a solution ?
Thanks for sharing !
Nope - still not working/unrecognized.
This thing is waaaay too heavy to be a tablet so the accelerometer is not exactly essential.
Currently using it for application testing on underpowered PCs.
Sorry I can’t be of more help.
