How to dismantle and change battery for HiPad Pro CW1526? Can’t find in google. Anyone done it or see a video on how to do it?
I will see if tech has some pictures to send you. Will answer you on Sunday, as now we are on holidays.
Did you check on Reddit? usually there are many useful post there
If there is something related in Reddit, it would show up in google search. But there is nothing. Would be good if there is a video on how to disamantle HiPad Pro CW1526 on youtube. But there is none. Totally have no idea how to open up, not to mention how to change the battery. BTW is it possible to do something like https://www.youtube.com/watch?v=K5wNk-blRC0 ? My problem is the screen is blank when I power on or when I charge. I do feel it vibrate when I power up but I only see a faint backlight but nothing else. I assume my problem is the battery died but it might be the screen that is faulty. Or is it firmware corrupted? The problem mention in Chuwi HiPad Pro white screen help - #4 by Debora fit my problem exactly. But there is no solution in that thread so I am struck. First instinct is open up unplug and plug back the battery and hope everything work fine. But have no idea how to do it.
i will see if i can explain to tech,i would appreciate if you can send me a video of whats happening so will be easier for understand,
Have uploaded the video as requested. Compress many times because max only accept 10MB so a bit blur video. Power up on only see backlight. I assume problem is battery so best open up to see if reset battery will help. Pls show me how to open it to reset the battery. Thanks.
Hi Maria, it’s been a month. Have u forgotten about my problem?
I am sorry for the delay. I asked Tech and they also think its battery issues. As it is quite old product. We do not have it anymore here to take a sample, to make a picture or a video showing how to remove the battery.
Tech also told me he does not recommend changing the battery unless is the same one, because it can burn the motherboard, pins must be the same also is quite important.
I am sorry
Hi Maria, no video no picture no problem. Is there a manual or diagram on how to open up the tablet? I look at it many times, I assume need hair blower to heat up and loosen the joints but there is no opening for me open it up. Don’t even know where to heat. Look more like is the screen side than the back side to open it up but really cannot find any opening. Change or not change battery come later. Need to open it up to check what is the problem first. If lucky just reset battery and it will work. This is provided I open it up correctly. I don’t want to anyhow force open and destroy everything. In the worse case if cannot repair can use the parts inside as spare part it will be a win. If do nothing and throw this is a electronic waste. Very bad for the environment and planet earth.
when you open maybe you make a video and pictures of every corner so i can show to tech and maybe they can help with that
Have uploaded the video as u requested. Hope it is not too blur as it was compress more than 90% of it’s original size due the video size limit of the forum. Do hope to heard from u soon. Thank u.
I am sorry maybe i did not explain well. What i mean is that you open the table and show us the inside so maybe tech can guide you. Because a video like that does not help much. Sorry is my mistake i did not explain well.
I am also going to see if i can provide more space for all of you to upload videos easily.
Hi Maria, if I can open up the tablet I would have already reset the battery long time ago. Like I said there is no screw or opening to pry open the tablet. That’s why I need your help to ask the tech on this as I have search everywhere on the net, no info on this at all.
Oh oh i understand i will show them the video. And see if they can explain.
Hi Maria, it’s been almost 3 weeks. No news again?
Very sad. Almost 3 months since this thread posted, nobody can tell me how to open up to reset the battery.
Sorry for the delay. I asked Tech again. And it must be done in a repair shop. Because The fully laminated screen needs to be heated to 60 degrees Celsius on a heating table before the machine can be disassembled.So that is why doing yourself may harm the tablet. Is better to go to a repair store and let them do it . I am sorry
Hi Maria, in this case is it possible to send me the correct Stock ROM and instructions on how to flash the tablet from a PC? From Chuwi HiPad Pro white screen help the problem mentioned in that post seem similar to mine. Problem is there is no proper instruction on how to flash the Stock ROM or what is the correct Stock ROM for my tablet. I did post a photo my serial number before. In case u miss it, it is Type:CW1526 HiPadPQ128G21071716. Pls help.
Check this
Thank u very much Maria. Will try it out soon when I am free.
