Beside the noisy fan also the bios settings are ridiculous. I also totally agree that threshold for fan activation should be around 80 degrees Celsius and for deactivation around 60.
Did someone try with a resistor to lower voltage at fan? Unfortunately the power cables are very thin and I have no proper tooling. But 100 Ohm should be sufficient.
Thank you ever so much parkerwb. The penny trick worked perfectly!
Before, the idle temperature was around 45 and the larkbox would incessantly oscilate between 45 and 55+ degrees. I thought I’d end up giving the LB away as I just can not tolerate such noise.
Now, it idles at 38 degc.
Only when I pushed all 4 cpus to 100% did the fan switch on. Strangely, it idled at 53-54 degC afterward. The fan isn’t cycling, so I’m happy. I guess the copper plate has warmed up and the heat has nowhere to go when the fan is off.
I did see a smaller chip; I didn’t give it the penny treatment, just a big dollop of thermal compound. ‘sensors’ (I run linux) shows the acpi chip at 60 degC.
Another defect in the fan controller code is a lack of hysteresis. The shutoff temperature is the same as the turnon temperature. When the fan turns off, it leaves the copper plate at 53-54 degc. It seems the fan is quieter now as well. Perhaps being clamped down reduces vibration as opposed to the old pad.
Yeah, bro, thats exactly what im thinkin about. Hope somebody create that hat. Well, server fan with radiator almost delivered from aliexpress. https://aliexpress.com/item/-/33023031982.html
Also i have 3pin mini reobas, and 3pin to usb cable.
Ill make same cooling as u did. After that start making 3d model of top cover for printing.
Still hopin that chuwi gonna do something, like upgrade or larkbox v2. I rly like that tiny cute pc… but so sad about bios and fan… whyyy… that could be truly amaizing gadget🥲
Recently, I made this replacement top cover to fit a different Heatsink+Fan for my Larkbox Pro to limit the annoying noise. It needs that you have access to a 3D printer and the design is not perfect but I though it might interest some.
Files and documentation are available here (for free): https://www.prusaprinters.org/prints/59693-chuwi-larkbox-pro-heatsink-top-cover-upgrade
That looks great! But makes the thing too tall isn’t true?
I don’t have any skills on 3d printing, but I was wondering on a “hat” with an 6x6cm fan inside it (like a Noctua NF-A6x25), with wide openings on the top. Pull out the nasty fan of the larkbox and put this “hat” over.
So, problems so far, it’s still audible but waaaaay better than the high pitched sonofab** inside the larkbox. Also, is always powered on even with the larkbox off.
Pros, the larkbox fan only ramps up after several minutes at 100% CPU usage, and in normal operation never ramped up (watching movies, surfing, etc)
I kinda like it … I’ll try to find a better fan, because this one, that I got from an ancient AMD k7 cooler, even at 5 volts spins fast, so as I said, it’s still audible. But damn, it’s hard to find a good 6x6 fan in black nowadays…
Use 40x40x20mm turbofan instead of 35x35x7mm turbofan.
The original air inlet and outlet holes were hollowed out to increase the heat dissipation effect.
The fan uses a 5V USB power supply, and the line is coupled with a 1/2W 150 ohm resistor, and the power consumption is reduced from 0.35A to 0.1A to control the fan speed to a silent level.
I also use a 12 volt fan connected to a 5V USB port on top - similar to MrUlla. I have the air flowing into the larkbox. But if i look at the picture of MrUlla it looks like the fan direction is pulling air out from the top… Anyone has an idea if we should blow air into the larkbox or pull it out? In my case i blow air into the larkbox and it is very cool and silent now - 48 degrees idle. I did replace the thermal pad with a copper coin and thermal paste - which also seems to knock of 2 degrees from avg
