Larkbox X 2023 iGPU 400Mhz instead of 750Mhz (solved), RAM 4000Mhz instead of 4800Mhz?
Serial: SLarBXGZ1H240501208 bios: DNB19C v0.03 x64
Can I use this patch?
Can I enable virtualization VT-X?
… Now we’re matching serials to downloads… I would need to reinstall my LarkBox X 2023, S/N SLarBXGZ1H240702225 - which would be the correct Win11 drivers? (my apologies for this partial thread hijack)
Thankyou for your reaction :slight_smile:
[edit: typo removed]
Do you have the problem with 400mhz? because you Larkbox is quite new, and that batch does not seem to have it
Yes you can use it.
Hi!
I have Chuwi LarkBox X 2023 affected with all 3 issues.
Serial Number of my box is: SLarBXGZ1H240304400
Memory Frequency: 4000MT/s
BIOS Version: DNB19C V0.03 x64
BIOS Build Time: 12/06/2023 15:52:51
EC Version: 1.02
Can I apply provided fix to resolve at least iGPU 400MHz issue?
Hi, my Larkbox X 2023 is an older one and has 4800 mt/s RAM, M.2 SATA SSD (AirDisk 512GB SSD SN14546) and VT-x enabled by default. I bought it on January 29th 2024 for 147,03 euros. (Just in case you’re interested.)
yes you can apply, it sorry sometimes this forum does not notice me
The “funny” thing is that, almost one year after they apparently “changed hardware” (to a slower DRAM model), they are still advertising it as a 4800 Mhz on their own product page:
“LPDDR5 4800MHz”
They still false advertise and noone obliges them to rectify.
Can you point me out where is that shown¿¿ Exactly, because we went through all the stores to remove 4800 and change into 4000. Maybe somethings was not changed.
Hola!
Me gustaria confirmar que ocurre con mi dispositivo, si tiene realmente la limitacion o no.
mi numero de series es SLarBXGZ1H231002031
gracias
No el tuyo no tiene ese problema
Mi número de serie es SLarBXGZ1H240505421 y actualizado a 24H2 GPU limitada a 400 si coloco la OC en modo suspensión y despierto la GPU llega a 750 MHZ
Intente parchear pero al terminar no reinicia.
SLarBXGZ1H240304599 necesito saber porque tras instalar cualquier sistema operativo no veo mas que negro en la pantalla cuanto todo esta correctamente instalado???
Necesitas preguntar a un experto.
Puedes entrar al Bios ?
si entro con F2
Puede ser por falta de drivers, que puedes descargar de la pagina web de Chuwi, soporte, descargas
el tema es que a la bios entro, selecciona iniciar desde USB la instalación de cualquier Linux y de windows 11 en modo seguro la hace perfecta y luego cuando reinicio normal no se ve.
Si pulso esc cuando carga me entra a modo de fallos y lo veo perfectamente incluso me carga el sistema, pero en cuanto reinicio vuelve a pasar teniendo todo actualizado al ultimo driver. Y no veo nada, la pantalla en negro.
no entiendo lo que dices: instalar en modo seguro, porque no instalas en modo normal.
puede ser que has cambiso algunos parametros del bios
