anyone found an usb-c power solution to power both the minibook and a 15w extrenal monitor ?
Not sure that a duplicator can do the job.
Best,
Vince
Best,
Vince
Not clear if you connected the monitor through HDMI or USB-C, or through USB-C only.
Please may you explain the connections?
just pluged the monitor on usb-c but seems the power is not enough. The monitor has only usb-c connector for video and power.
I think you have to solve USB-C connection on minibook first. I can’t connect any device at USB-C port, no device is detected. And yours? Did you try to connect any other peripheral?
mine also cannt detect monitor when using usb c vga
I just bought a LCD touch portable monitor (without Battery) and it is ok, i have a picture without problem. But i must use the ac adaptor to have picture on my monitor
Which adaptator ? Can you give us a model ?
