Try to reinstall battery driver, if it’s doesn’t help probably you have problem with battery or with chip that detecting it.
Contact service@chuwi.com if reinstalling driver doesn’t help.
Thank you, I actually don’t know where to find the battery driver, I have seen on the forum a package of drivers (but I’m a bit scared because of having read about fingerprint drivers and others having to be reinstalled manually. For the moment since I have no issue with the others seeming functioning correctly I try to avoid adding new problems).
I’ll explain the whole experience in a new thread just not to hijack current one. Thanks again
I am having the same problem. Can you please tell me whether it is solved and how it is solved?
Regards
