Minibook X 2023 50hz choppy ghosting
Tried it like described here
Used DSI-1 for the monitor. But didn’t try hard enough to make it work. In addition I would prefer 60 over 90 Hz.
Cheers, Jaap
Thanks @Obamna! Worked perfectly for me to go to 90hz. Makes scrolling so much smoother!
Thank you for posting those screenshots, @Obamna. I just got my Minibook X and am working on adjustments, and you helped me get my screen refresh rate up. I appreciate it!
Update: after a year of using 90hz, the screen started showing artifacts for about 10-20 sec once a week, like the ones you get with wrong setting in CRU but milder. So I switched to 60hz with no artifacts for a month.
Hm, i don’t even get 60hz to work on my panel, ends up in messed up screen of colorful lines and artifacts.
I could live with 50hz, but the original Dead Space game refuses to start if there is no 60hz resolution mode present.
I found now workaround for this as of now.
Have you tried all the other timing presets, not just Exact reduced?
Some, but not all.
I have tried Manual, Automatic PC, Native PC and Exact- and Exact reduced of course.
Well, chuwi guys did say that the panel is locked at 50hz because higher does not always work, so perhaps you got unlucky. You could try all the other timings, manually change the timing numbers randomly or perhaps updating intel drivers could help
@Obamna
Thanks for your input!
I have now tried the CVT-RB2 standart timings for 60hz and CVT-RB1 standart timings for 90hz and those work!
Anyone know if this works with the 2025 n150 version? I’m on the fence about getting one, but if I can get it to 60Hz it would be a point in its favour.
Hard to say.
For the old minibook, I know of the 2 versions of the screen panel -
  1. The early one with great colors, no ghosting and native 60hz. Was replaced very quickly by the new one;
  2. The new one, barely passable colors, medium ghosting and underclocked to 50hz because of how shittily inconsistent they are.
If they are still using the same number 2 panel as n100 version - then it will probably work (no guarantee). If not - then your guess is as good as mine.
Tho if it is “natively” 50hz on the n150 version, then I’d guess it is the same panel as n100, since 50hz is pretty rate for any panel.
Thanks, I think I’ll hold off for now and see what other options exist.
