Ubook Xpro 2023 pen lag and unrresponsiveness, is it normal?
Hi, I received my Ubook Xpro (2023) with the keyboard cover and Hipen H7 yesterday.
The tablet itself is working fine, but when I try to use the pen, it lags a lot and only detect fast movements, when I try to move it slowly across the screen, it doesn’t register the click, the cursor moves, but with a lot of lag and the input is not registered.
This is specially noticeable in drawing apps (the main reason I bought this tablet), if you try to draw a line slowly, it doesn’t draw the line at all, only registers fast strokes, which makes this unusable to draw on it.
I tried with a linux live distro from usb and the problem persists, so it has to be hardware related, not windows, not windows ink, but the tablet itself, maybe the it uses some sort of smoothing that causes this and for artist like me, this is a deal breaker.
Is there any way to fix this or do I have to return the tablet and look for a better alternative?
Here’s a video of the problem (set as private video on youtube, I don’t want to talk bad about you, just want a fix).
Example of input lag and not registering clicks with hipen h7
Ok, so this is what I’ve found so far.
It is related to the screen’s digitizer settings, so, it’s something they can fix with an update, they just have to lower the smoothing settings like they did here and provide a way to flash the changes to the controller.
The smoothing settings are WAY TOO AGGRESSIVE, they need to lower them to make this tablet useable for artists or to even write on it properly.
Same or similar problem here
Did you finally fix it? I’m doing a return if it doesn’t work.
Chuwi support service could use some improvement… there is no phone here in Europe, just an email.
No, they didn’t fix anything.
And It could be fixed by an update, but they just don’t seem to care.
UBook X 2023 here. Multiboot windows 11, debian 12, FydeOS 17, BlissOS.
I download sketchbook app from Google play on FydeOS 17.
No lag, no issues, work perfectly.
Have you tried pressing the pen slowly? a soft stroke?
Does it register any input?
That’s our problem, you have to press firmly or draw a fast line for the pen to register any press at all, if you do it slowly or softly, it doesnt draw the line and that’s a BIG problem for artists.
I’ll try again and record it
Im having exactly the same struggle with the UBook XPro 2023 here. Is there any update on this? @Chuwi it would be great to have your help here
I have the same problem.
Handwriting and drawing is impossible for me with the Ubook x pro, windows 11, and any of my usual apps - onenote, paint, whiteboard.
I’ve recorded it here:
you can see what my handwriting normally looks like
Has anyone got anywhere with this?
I will have to return the device if I cant get this sorted
Do you all have the i7 version?
I’ve noticed from youtube videos that people with the i5 version have a much smoother writing and drawing experience :
I’ve made the changes outlined in this thread: Need YOUR help fixing my Minibook X touchscreen
Handwriting performance has improved a lot: Improved stylus - Uboox x pro - Create and share your videos with Clipchamp
PROCEED AT YOUR OWN RISK
THIS IS MY MODEL: Book XPro - Intel Core i7 and Windows 11, 8GB RAM 256GB ROM and 2160 x 1440 IPS
This was my original cfg
0x95,0x02,0x69,0x01,0xcf,0x0a,0xc0,0x21,0x80,0x16,0xc6,0x0a,0x32,0x07,0x45,0x90,0x04,0x00,0x03,0x03,0x1e,0x03,0x64,0x46,0x56,0x04,0x11,0x34,0x0f,0x05,0x7e,0x02,0x63,0x03,0x62,0x68,0x22,0x22,0x33,0x00,0x00,0x80,0x00,0x00,0x02,0x28,0x34,0x05,0x1e,0x08,0x0a,0x14,0x50,0x14,0x08,0x06,0x08,0x06,0x23,0x40,0x99,0x11,0x34,0x8d,0x14,0xff,0xcc,0x18,0x33,0x4c,0x1b,0x33,0x77,0x1e,0x1e,0x03,0x55,0x23,0x32,0x14,0x02,0x17,0x00,0x26,0x21,0x48,0x90,0x14,0x32,0x1c,0x23,0x11,0x12,0x13,0x23,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x37,0x5a,0x3c,0x70,0x00,0x57,0x00,0xe3,0x1e,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x99,0x8d,0x82,0x7c,0x77,0x73,0x11,0x14,0x18,0x1b,0x1e,0x00,0x64,0x4b,0x93,0x80,0x00,0x0c,0x94,0x0f,0x0a,0x08,0x00,0x08,0x60,0x14,0xa0,0x82,0xa0,0x82,0x03,0x4b,0x12,0x03,0x02,0x03,0x00,0xbb,0xbb,0x82,0x96,0x78,0x78,0x43,0x43,0x44,0x44,0x00,0x00,0x00,0x00,0x00,0x00,0x33,0x33,0x81,0x81,0x90,0x01,0xc2,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x4d,0x02,0xe4,0x24,0x27,0x26,0x2a,0x28,0x29,0x2c,0x2b,0x1a,0x18,0x16,0x19,0x17,0x14,0x15,0x13,0x12,0x0f,0x0b,0x10,0x11,0x0e,0x0d,0x0c,0x09,0x0a,0x08,0x07,0x05,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0x24,0x25,0x2b,0x28,0x27,0x2c,0x2a,0x29,0x1a,0x19,0x18,0x17,0x16,0x15,0x13,0x14,0x12,0x0f,0x0c,0x10,0x11,0x0d,0x0e,0x0a,0x0b,0x09,0x06,0x08,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2f,0x30,0x32,0x34,0x33,0x35,0x37,0x36,0x38,0x3a,0x39,0x3b,0x3c,0x3e,0x3d,0x40,0x3f,0x41,0x42,0xff,0xff,0xff,0xff,0x30,0x2e,0x34,0x33,0x32,0x37,0x36,0x35,0x3a,0x39,0x38,0x3d,0x3b,0x3f,0x3c,0x40,0x3e,0x41,0x42,0x00,0x00,0x00,0x00,0xe0,0x1e,0x36,0x73,0x03,0x00,0xc8,0x32,0x34,0x35,0x0b,0xb8,0x24,0x24,0x64,0x40,0x00,0x32,0x00,0x00,0x00,0x00,0x03,0x00,0x03,0x03,0x07,0x03,0x03,0x14,0xc8,0x19,0x1b,0x15,0x18,0x1b,0x1e,0x21,0x82,0x64,0x64,0xe0,0x01,0x00,0x60,0x1d,0x13,0x1d,0x13,0x8d,0x13,0x64,0x01,0x15,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc7,0x09,0xc0,0x0a,0x77,0x00,0x66,0x00,0x82,0x0a,0x07,0x08,0x66,0x00,0x77,0x00,0xc7,0x09,0x0a,0x10,0x8b,0x09,0x09,0x12,0xc7,0x09,0x0a,0x1e,0x70,0x70,0x00,0x10,0x24,0x04,0x43,0x30,0x00,0x00,0x00,0xea
And this is my new cfg with the filtering edits:
0x95,0x02,0x69,0x01,0xCF,0x0A,0xC0,0x21,0x80,0x16,0xC6,0x0A,0x32,0x07,0x45,0x90,0x04,0x00,0x03,0x03,0x1E,0x03,0x64,0x46,0x56,0x04,0x11,0x34,0x0F,0x05,0x7E,0x02,0x63,0x03,0x62,0x68,0x22,0x22,0x33,0x00,0x00,0x80,0x00,0x00,0x02,0x28,0x34,0x05,0x1E,0x08,0x0A,0x14,0x50,0x14,0x08,0x06,0x08,0x06,0x23,0x40,0x99,0x11,0x34,0x8D,0x14,0x88,0x87,0x33,0x33,0x33,0x33,0x34,0x34,0x1E,0x1E,0x03,0x55,0x23,0x32,0x14,0x02,0x00,0x00,0x26,0x21,0x48,0x90,0x14,0x32,0x1C,0x23,0x11,0x12,0x13,0x23,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x37,0x5A,0x3C,0x70,0x00,0x57,0x00,0xE3,0x1E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x99,0x8D,0x82,0x7C,0x77,0x73,0x11,0x14,0x18,0x1B,0x1E,0x00,0x64,0x4B,0x93,0x80,0x00,0x0C,0x94,0x0F,0x00,0x00,0x00,0x08,0x60,0x00,0xA0,0x82,0xA0,0x82,0x00,0x4B,0x03,0x03,0x02,0x03,0x00,0xBB,0xBB,0x82,0x96,0x78,0x78,0x43,0x43,0x44,0x44,0x00,0x00,0x00,0x00,0x00,0x00,0x4B,0x4B,0x65,0x65,0x8C,0x00,0x82,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0xCE,0x02,0xE4,0x24,0x27,0x26,0x2A,0x28,0x29,0x2C,0x2B,0x1A,0x18,0x16,0x19,0x17,0x14,0x15,0x13,0x12,0x0F,0x0B,0x10,0x11,0x0E,0x0D,0x0C,0x09,0x0A,0x08,0x07,0x05,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x24,0x25,0x2B,0x28,0x27,0x2C,0x2A,0x29,0x1A,0x19,0x18,0x17,0x16,0x15,0x13,0x14,0x12,0x0F,0x0C,0x10,0x11,0x0D,0x0E,0x0A,0x0B,0x09,0x06,0x08,0x03,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x2F,0x30,0x32,0x34,0x33,0x35,0x37,0x36,0x38,0x3A,0x39,0x3B,0x3C,0x3E,0x3D,0x40,0x3F,0x41,0x42,0xFF,0xFF,0xFF,0xFF,0x30,0x2E,0x34,0x33,0x32,0x37,0x36,0x35,0x3A,0x39,0x38,0x3D,0x3B,0x3F,0x3C,0x40,0x3E,0x41,0x42,0xFF,0x00,0x00,0x00,0xE0,0x1E,0x36,0x73,0x03,0x00,0xC8,0x32,0x34,0x35,0x0B,0xB8,0x24,0x24,0x64,0x40,0x00,0x32,0x00,0x00,0x00,0x00,0x03,0x00,0x03,0x03,0x07,0x03,0x03,0x14,0xC8,0x19,0x1B,0x15,0x18,0x1B,0x1E,0x21,0x82,0x64,0x64,0xB4,0x00,0x00,0x60,0x1D,0x13,0x1D,0x13,0x8D,0x13,0x64,0x01,0x15,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC7,0x09,0xC0,0x0A,0x77,0x00,0x66,0x00,0x82,0x0A,0x07,0x08,0x66,0x00,0x77,0x00,0xC7,0x09,0x0A,0x10,0x8B,0x09,0x09,0x12,0xC7,0x09,0x0A,0x1E,0x70,0x70,0x00,0x10,0x24,0x04,0x43,0x30,0x00,0x00,0x00,0x1B
I have the i5 version and I don’t know if those settings will work for me or will make it worse.
I followed the instructions here: Need YOUR help fixing my Minibook X touchscreen
I made a backup first so I was never really worried about breaking my computer
If you read through the instructions in the thread and feel like you’ll be able to made a back up and then use guitar tutor pro (gtp) to make the changes outlined, then I’d go for it. If you read the thread and got lost, I would leave it and wait for someone else with your exact model to give it a go.
IT WORKED!!!
It worked with your settings!
Now, even if I move the pen slowly or press the secreen softly with it, it recognizes the input and draws!!
OMG! this has improved it’s usage a lot!!
Now I can draw on this tablet pc.
Thanks again and people with the i5 version, you can safely use the settings posted by @nicoleahmed on your Ubook Xpro 2023 i5, it does work like a charm!
Didn’t work
Pcan u help me please i will pay you
dont worry about the fact that when i reached out and said this was an important gift for my daugter’s first pc 3 weeks before her birthday i glad you reasured me that thier would be no issues with that dead line so thankfull it showed up 3 weeks after her birthday really love the loyal service’s you stand behind it’s fine best part was when she couldn’t use it either becuase some imaginary ghost that was using it the hole time made me feel real speacial that i choose the finest quality products and customer services for my daughters first pc so i had to buy a new one while chuwi Nightmare cw1535 became my new favourite toy also love the extended loyal services for the device software so easy to maintain this master peice of quality performance 1.2 Ghz brick that not advertised when purchasing this octa core missing the octa and also just quad core make me feel your and honest man with high standards you live by so if you be so kind to maybe end the pen that i ordered would be above and beyond any service i seen before keep up the great work over thier at slum tech chuwi land selling lies and broken promises to little girls for birthday gifts for this i rate you 5 big ones you deserve thank you biggest fan and supporter shout out
