нашел решение проблемы с писком катушки на minibook x n150 .
панель управления > все элементы управления питанием > электропитание >изменение параметров схемы >и в активной схеме Изменить дополнительные параметры питания > управление питанием процессора > в максимальном состоянии процессора ставим 99% .
и писк проходит совсем . Как при подключенном зарядном устройстве так и работа от батерее полная тишина .
I found a solution to the problem with the squeaking of the coil on the minibook x n150. control panel > all power management elements > power supply > change circuit parameters >and in the active circuit, Change additional power parameters > processor power management > set the maximum processor state to 99% . and the squeak goes away completely . Both with the charger connected and the battery operation is completely silent .
Попробовал решение по Вашей схеме - не сработало, шум сохранился.
Устройство может от этого сгореть?
I tried the solution according to your diagram, but it didn't work, the noise remained. Could this burn out the device?
in general, what I wrote there is a problem that the Turbo Boost stops working and the processor only works at its standard frequencies.
I found another way out. I installed Windows 10 and installed all the drivers from the official website through the administrator. I’ve been using it for so long, the sound has disappeared, and I didn’t have to make any additional settings.
windows 11 is very heavy and constantly loads the processor, and constantly does something in the background, which is why the power part of the laptop gave these unpleasant sounds.
and as laptop repairmen explained to me, squeaking chokes or coils is normal, even premium laptops have this disadvantage.
