MiniBook x, N100, half screen after reboot (in linux)
Dear Chuwi-Support,
ZMinBXHY4H240501997
October 2024
Problem:
I have installed Debian 12.8. Screen was displayed very well.
After reboot it was only viewed a half screen.
Solution described in InstallingDebianOn/Chuwi/MiniBook - Debian Wiki is not working.
Please give me a hint, whats going wrong (Firmware).
Regards,
Thomas
Those guidelines are not for a Minibook X N100. Until I installed a distribution with Kernel 6.11 I have had the same problems.
You might try to install a newer kernel or a Linux distribution with a newer kernel.
I have successfully installed Ubuntu 24.10, and Fedora Core 41 on the Minibook X N100.
Dear jaap.
Thank you so much regarding your hint.
Ubuntu works very well.
Regards,
Thomas
You’re welcome. Did you see this?
Dont poweroff the laptop with a boton, type sudo reboot or sudo poweroff, thats works me
