Hi… Need help after re-installing Win 11 in Minibook X N5100, Touchpad and Touchscreen stop working… I notice that in Device Manager (HID) don’t detect the hardware (Goodic or else)… Please help with the driver for Touchpad and Touchscreen… Thankyou…
Could you find a way to solve this problem?
Hi… Some tutorial and driver for touchscreen and touchpad is avaliable for Minibook 8, but not compatible with Minibook X… and my Minibook X touchscreen and touchpad still not function…
Yesterday I solved the TouchPad and touchscreen problems installing all drivers for MiniBook X. There is a link to download the drivers in this forum.
Please check that!
Best regards
Yess… Your solution is perfect…
Minibook X driver problem solved with this file: minibook x
Literaly you must install the driver one by one by clicking all the .exe files, and right click then install the “setup information” files… Thanks.
You could install all drivers at one time by adding drivers to the top folder…
Hello nuno…
Could you explain how to do that? I downloaded that file and extracted it. There are 11 folders inside the Minibook X folder, ranging from Bluetooth to System Devices.
I’m a NOOB with this stuff but I just got my Minibook X yesterday.
While I THOUGHT i was deleting apps I didn’t need I guess I deleted something I shouldn’t have.
What files go into what folder and how do you install them once they are there? There are so many files to this Zip file!!!
Sorry to impose on you like this. I’m more comfortable doing a firmware reset if they have the file and how to get the minibook to go into firmware reset mode from power off.
Any help would be greatly appreciated.
Before making any changes, You can search on Google how to make that change.
