Need BIOS: corebook x cwi529 JCorBXIY1H240801886
Security boot dont work, and i want to reload bios. Maybe its working.
I’m not sure what your problem is.
What changes have you made to the BIOS to prevent Secure Boot?
In Security boot I went to Key Management and thereby clicked on install default Secure Boot keys. After these operations I can’t enter Windows and thus the BIOS displays the error ā€œInvalid signature detected. Check Secure Boot Policy in Setupā€. After all this I can’t disable Security Boot because it is not clickable.
You are asking about:
To start Safe Boot in Windows 10 or 11, you can:
Select Startup Settings
Select Restart
Press 4 or F4 to start Safe Mode
Press 5 or F5 to start Safe Mode with Networking
  • Contact support
This all doesn’t work, it only launches the BIOS.
I even tried to return everything to default, the result is the same.
You may have broken Windows.
If the BIOS works normally. Just install Windows.
I’ll write when I do it, thanks for now.
Just in case i checked and WIndows and Drivers can be downloaded from here
