Hi guys,
after turning off the pc I put it in recharge. it never came back on. The charge LED lights up. Pressing the on button, the blue led lights up but the pc does not boot. It can only be turned off by keeping the pwr key pressed for a long time. Any ideas?
the pc is one month old.
Hi, I have the same problem. Did you find a solution?
Hi herman,
after contact with the call center, the product was returned because it was purchased within the first month.
For anyone that had black screen during boot up of HeroBook pro 14’1, I have solved the problem disassembling the rear and removing the metal dissipator of mother board: i have found the rubber dissipator of graphic processor non properly located over the chip, this thing creates disturbs on the LCD during boot up and, when turned on, the image’s block on deskstop. fixed the problem, right now the laptop works perfectly and i’m writing this comment from it!
