Problems after removal of android partition and reinstallation of windows 10
I have. I did download them and unzipped them in one file. During unzipping a message appeared about broken files. I will try again.
Should i create a bootable usb with them and reinstall them to tablet or the bootable usb is not needed.
When i removed the android patrition i had t go to Bios and delete the partition with all contents of C drive https://www.youtube.com/watch?v=KhBgaYiesLM
Then i plugged the bootable usb drive with windows 10
do i need to do similar procedure with the files you sent me. Please explain as i attempted to go into Bios again…but it was confusing and windows will not let me format the c drive.
Also last night i reinstalled windows through the recovery procedure and i installed Java. It is a bit better to be honest
Do you think that java script helps?
Thank you so much
You need to format usb to ntfs, name it WinPE, copy files to a usb and boot from it, then windows will be installed automatically. If you will get an error- install android first.
Probably java helps only with websites and applications that use java.
You are a star. I will see how it goes with java and network adapter that i am waiting to be delivered. If unsuccesful i will redo the installation. Thank you so much
Last question, if i do the procedure with usb etc, is there a way to prompt the tablet to boot from the specific usb? or i simply switch off, plug usb switch on and it will reboot from usb automatically? Thank you
Press F7 continuously at startup and you will see a boot menu with a choice of boot devices.
In order not to have driver problems, the Reinstallation of Windows 10 should not be done from Zero with the ISO on a USB stick, but hot, as follows:
1-Insert in the Slot, a Micro-SD Sandisk Extreme 32GB (NTFS Formatted)
2-Copy the ISO, downloaded from Microsoft, onto the Micro-SD.
3-Tablet with battery over 80% charged.
4-Connected to the Power Grid, via the AC / DC Cable and Power Supply.
5-Start Windows. from “This PC”, select the Micro-SD.
6-With the Right Mouse on the ISO, Select and click on “Mount”, when “Setup.exe” appears, Right Click on the Mouse, and click on “Run as Administrator”.
Follow the attached instructions:
for 1909:
for 2004 (20H1):
Good luck!!.
Thank you for your post. After multiple attempts to do all these …i did quit… Searching through histort i think the tablet had windows 8 when first bought.
Some of the diagnostics run came with the result that there was a problem with firewall and the browser etc. I tried to unisatll microsoft edge but unsuccesfull despite using microsoft power cell. I ended up intsalling mozilla, stopped usng micorsoft edge. This plus an external network adapter (which is not working when i use microsoft edge as a browser) seem to work.
Fed up with it now. Anyhow that you
What are the specs I need to have for any replacement [type of connection etc].
Do you have a diagram/photo of the internal layout?
I have not had any need to open the casing before. How do I open it up?
Since I had a keyboard for my Hi10Pro, I just took the easy option of getting a USB WiFi adapter but do like the idea of fitting one inside in place of the original. A much neater solution.
Denis
I wrote instruction for Hi10 air but hi10 pro has the same pinout.
