Recharge time and led
Hi, I have this notebook from 1 day. How long does it take to fully recharge the battery? When it’s charged, does the orange LED go out? Thanks.
Hello
Without use, with original charger ,it should taken o more than 2h to fully charge and light goes to green then.
Using it while charging it depends on the activities performed in the laptop.
At least, this is the numbers and behavior I experienced.
Regards
Usully you can charge it 1-2 hours, but you may charge it longer to get the full capacity.
The light will change to green while fully charging. if the orange light flashing, it must be some problems with battery.You can consult customer service to get better technical support.
