I’ve installed Windows 11 on my CHUWI UBook CWI509 N4100 and it works everything but the sound card.
I’ve tried installing drivers from here:
to no avail.
I’ve also installed Debian Bullseye in dual boot and everything, including sound, works fine.
Audio used to work fine with Windows 10.
Maybe someone has some suggestions?
Thank you in advance…
Hi Ruben,
thanks for answering, I made a clean install to be sure to have a clean system.
Drivers from Chuwi website and drivers from Intel website cannot be installed…
Install the intel driver support assistant and it will detect and install the latest drivers. The realtek audio drivers are bundled with the graphics driver.
The only bluetooth device I used on the ubook was a simple Chinese TWS headset and it worked correctly. I’m trying to reinstall Windows 10 from the factory (Chuwi) let’s see if it solves the problem with the phone and drivers.
I reinstalled Windows using a backup image made in Windows 10 ( factory), but the sound problem got worse, now neither the sound nor the microphone work.
Can someone help me? I need the sound card driver, why doesn’t Chuwi setup the drivers like other manufacturers?
You may check with a live Linux distribution (Debian Live, Knoppix, etc.):
if the sound works then it’s a problem with Windows11 drivers;
if it doesn’t work then it’s an hardware problem…
I tried everything, installed 3 different windows images and in all the sound was not installed, with realtek driver the driver was installed but the sound didn’t work, I read in a post here on the forum a person with a similar problem, he said that after hitting the back of the ubook the sound came back, so I opened the ubook and reconnected the speakers and the sound started working again, but I’m not sure where the problem is with the hardware. Does anyone have any idea what this problem might be?
after a lot of troubles looking for the right driver, I found that the problem could be related to this issue confirmed by Micro$oft:
However, fiddling in the BIOS settings I found a workaround to my problem.
Entering the BIOS settings (Fn+F7 at boot), under Chipset, South Cluster Configuration, HD-Audio Configuration, there is “Audio DSP Compliance Mode” which can be set as “Non-UAA (IntelSST)”, which is the default, or “UAA (HDA Inbox/IntelSST)”.
If it’s set to “UAA (HDA Inbox/IntelSST)” the device changes its name and its hardware IDs.
It also changes the driver to use, and (bingo!!!) this driver works!!!
