Spanish layout in Aerobook
I have recently bought an Aerobook laptop and I want to use the Spanish language, but when I have configured Windows 10 for this language, the simbols “< >” have disappeared.
Can you tell me how I can get these keys?
Since Chuwi does not manufacture keyboards with Spanish disposition (I would like to be my language), you have two possibilities to use it without difficulty:
If like me, you know typing, I have put the keyboard in Windows as Spanish, Spain and logically there are differences between the symbols of the keys and what is then written, but it does not affect since you do not look at the keyboard. Indeed, the keys greater than and less than are lost. To recover them, you can install the script whose link I put below and you can use these keys by pressing Ctrl +, and Ctrl + .
That script once the program is installed, is just double click and the program is already running and it is running alone. -It can also be put in the start menu and will be activated only when turned on.
The other option is to put the Spanish keyboard, the United States and so the keys will match what you type on the entire keyboard.
En español: Ya que Chuwi no fabrica teclados con disposición española (ya me gustaría por ser mi idioma), tienes dos posibilidades para poder usarlo sin dificultad:
Si como yo, sabes mecanografía, he puesto el teclado en Windows como español, España y lógicamente hay diferencias entre los símbolos de las teclas y lo que después se escribe, pero no afecta ya que no miras el teclado. Efectivamente, se pierden las teclas mayor que y menor que. Para recuperarlas, puedes instalar el script cuyo enlace pongo a continuación y podrás usar dichas teclas pulsando Ctrl , y Ctrl .
Ese script una vez instalado el programa , solo es darle doble click y ya se ejecuta el programa ya se queda funcionando solo. -también se puede poner en el menú de inicio y se activará solo al encender.
La otra opción es poner el teclado español, estados unidos y así coincidirán las teclas con lo que escribas en todo el teclado
Descarga los ficheros aquí
Ejecutas el exe y despues dás doble click sobre el fichero teclas y ya funcionarán las < y >. Lo acabo de hacer y funciona perfectamente como podrás comprobar
Para no tener que hacerlo cada vez que enciendas, puedes crear un fichero exe con las instrucciones del fichero teclas y colocarlo en la ruta: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp y así, cada vez que inicies se activará automáticamente
Thanks a lot
Muchiiiiiiiiiisimas gracias; me has dado buenas ideas
Aprovechando que te lo explicaba, he hecho el fichero exe y lo he puesto en la ruta que he indicado y ya funcionan los símbolos al encender
But it is any way to get the products with a Spanish keyboard without needing to use some stickers?
Hola,
en AMAZON hay disponibles unas pegatinas de teclado TRANSPARENTES. Yo las he colocado y son de gran utilidad. Un compañero lo ha visto y también las ha pedido. Valen 4€…
Saludos,
pegatinas spanish teclado
