Hi 2 all.
Can i use this ssd MPC0320/0H1 in my MiniBook?
I want to install linux on it and use two OS on my device?
Won’t fit, unless you use a hammer
According the link given below the picture depicted is of the actual SSD. The connecctor is a mSATA conector (8 fins connnector, then a slot, then the (approx) 20 contacts.) The Minibook SSD slot connnector is depicted also below. It has 5 fins, then a gap in the connector. Therefore it won’t fit. What you need is a SSD like the bottom picture, that will fit the slot. It has a M2 slot, and both the m2.sata and M2.nvme will fit.
However, the n4100 CPU is not compatible with NVME while the M3-8100Y is. So a M2.sata will fit, and if you have the 8100Y thena m2.NVME also will fit and work.
The name of the SSD interface you’re looking for is M2 NVME. Your SSD has a msata,
https://www.memory4less.com/samsung-pm830-32gb-sata-6-0-gbps-ssd-mz-mpc0320-0l1#
Your proposed SSD.
Chuwi SSD slot
SSD compatible with the Minibook
Thanks. It was my mistake.
My minibook still goin to me. So, i don’t have the device at the moment, but found ssd.
Sorry.
No, I don’t think so. Because these are not for mini-books because they will not sit properly on your device. You can only use it as an external drive.
The Minibook slot is totally different from MPC0320/0H Slot. I think this information will be enough. If you are looking for more information you can check the details from the below link.
I also made the same mistake. You should see what is your system properties. I purchased an SSD with two cuts and after purchasing that I found that I need NVME with 1 cut. https://www.allhdd.com/dell-400-bfep-960gb-pcie-nvme-ssd/ I asked my supplier to replace it and it worked great after replacing it.
Yes, you can use the MPC0320/0H1 SSD in your MiniBook to install Linux. As long as the SSD is compatible with your MiniBook’s interface (likely NVMe U.2 SSD (Solid State Drives :: NVMe U.2 SSD) or SATA-based SSDs), you should be able to install Linux on it and run dual operating systems. Just make sure to check the physical dimensions and connection type to ensure a proper fit.
