We bought some of your notebooks less than a year ago.
One of these notebook features a swollen battery that even raised the trackpad.
We are very concerned about our safety and health, considering that the notebook travels like any mobile device.
We believe that the situation can worsen by causing damage to things and people , and in this regard I would like to know how you intend to provide.
As you will read from the signature below, we are distributors of starter batteries and more, and we offer to install the battery ourselves at a trusted laboratory, but we need to replace it. The barcode on the carton box is 6935768752837 and its product number is CBPROQ256G20102800.
I await instructions on how to proceed, sure of your understandable and prompt reply.
I had the same issue with a corebook pro and here are my 2 cents.
Laptop was bought in nov. 2020, and around november of 2022, the trackpad started to do weird things. After a month or so, the battery was clearly swelling and pushing the trackpad out, I could even see the battery bellow the trackpad, that was the cause of the malfunction.
Since I didn’t want my laptop to became e-waste (this laptop does NOT work without a battery inserted in, every laptop that has integrated battery does this) I bought an aftermarket battery from aliexpress.
This replacement does not have the plastic frame and as such, could not be reused either (manipulating an old swolen battery is DANGEROUS, it may explode or exhale toxic gas, please do not try to keep the plastic frame) you also would need double sided tape to install it.
In order to replace the battery I had to remove a screw holder from the back case as it does not close completely with it. This may be troublesome for some. After replacing the battery, note that the laptop reboots itself at the boot logo twice. This is completely normal as it is detecting the new one. Trackpad stopped doing weird things also.
If your laptop still has warranty (which is not my case since the laptop was ~3 years old) I suggest you always ask Chuwi after-sale service first. I did and they were willing to sell me a new official battery, but since sending battery goods to the EU is troublesome it would be about 100~ euros (with warranty I would only pay for the sending). The aftermarket battery from aliexpress is roughly 50€.
